Version
6.6 and Not the Version specific
Issue
Error in Integration failure monitor (from iVend to SAP), below is the error:
System.Exception DI [OCRD.GroupCode] , 'Linked value 0 does not exist'
at ReplicationSBOIntegrationWinSer.IntegrationObjects.Customer.Replicate(Direction From, Direction To, Int32 DatasetRowID) at ReplicationSBOIntegrationWinSer.Integrator.MainStart(DateTime LastRetryAt, Boolean Retried)
These are for the type Customer and update events.
Solution
Go to the SAP Database and run the below query:
Select * from OCTG
And check that, if result have any entry as Zero (0) in the column GroupNum or not?
If there is any entry for the GroupNum column as zero then ask customer to change it, as it should not have zero in this column.
(This is for Payment Term, and it should not have any entry for GroupNum column as 0)
