Integration Error Credit Card - not set neither for the warehouse '301' nor on the Retail Tender
Product Version:
6.5 Update 6 Patch2
Problem Statement -
(INC0011125)  Sale Transaction stuck  on Integration Failure Monitor with error message System.Exception: Credit Card -  not set neither for the warehouse '301' nor on the Retail Tender in SBO at ReplicationSBOIntegrationWinSer.IntegrationObjects.Base.IntegrationBase.GetCreditCard
This issue can be resolved by applying the latest build (Stored Procedure Integration_TransactionPayment), extracting them and applying the zip files through Application Patches.
Steps if any:
Below are the steps which we require to follow for the analysis issue.
1.Require to check Account Type on Table TrxTransactionPayment.
2.Run stored procedure Integration_TransactionPayment for problematic Transaction it will return Account Type Null that means 11 accountype is not handle on stored procedure Integration_TransactionPayment.
Constraints / Scenarios :
