If possible to add more than 5 panels of button in the POS Designer
iVend 6.6 With SAP B1 9.2
Is it possible to add more than 5 panels of button in the POS Designer ? Customer require 5 different panels on iVend POS Screen through customization
As of now it is not possible to add the button panels in POS designer as it has been already set to 5 in development phase.
Not Aplicable
Custom Button Panels in the Management Console and the POS in iVend Retail
Introduction This knowledge base article will assist developers on how to create a custom button panel in the iVend Management Console and at the POS. Refer to. the CitiXsys Knowledge Portal for more details and code samples. Purpose The main purpose ...
Custom Button Panels in the Management Console and POS in iVend Retail
Introduction This knowledge base article will assist developers on how to create a custom button panel in the iVend Management Console and at the POS. Environment: iVend Version 6.5 Purpose The main purpose for allowing the creation of custom button ...
Block User Menu Button on POS
Problem statement User Menu button found in iVend POS. Environment iVend 6.6 Symptoms User is developing an Add-On where they need to block this button so that only Manager type users can access. However, user cannot find any event or example that ...
POS - Custom Button panel
Introduction: iVend Add-on Framework is used for writing Custom Business Logic independently by a programmer. iVend Addon allows to extend business logic either in Management Console or at the Terminal POS. The addon framework allows deployment of ...
