how to Restrict Users to Change Caption from POS
iVend 6.6 7989
How Can we restrict POS Users to Change Caption of button From POS
User having Security Rights to change Caption
Resolution/Workaround:
Change User Security Rights access level for "Allow Change Caption"
1. Go to Security Role
2. Open Particular Security Role in Edit Mode
3. Go to Assign Security Rights
4. Drill Down Application Setup Menu
5. Change Access Level "NO" for Allow Caption Change Rights
How to restrict POS user to change UOM on POS
Product Query : How to restrict POS user to change UOM on POS Answer : There is no specific setting in POS to restrict a particular UOM column. However, iVend provides a feature wherein, if you disable the setting "Open Item Edit View On Column ...
Restrict user to change the product quantity in POS screen.
Environment: iVend 6.6 Problem statement: Restrict user to change the product quantity in POS screen. Solution/Work Around: As a workaround,in the retail profile , you can check box "change qty" inside the manager override so whenever user changes ...
Restrict particular users to access warehouse
Environment : iVend 6.6 with SAPB1 Problem Statement : There is need to restrict particular users to access warehouse & its relevant information in iVend Various Screens. Resolution/Work Around : Whenever you create any warehouse in SAPB1 , it will ...
Restrict Transaction Search
Problem statement : When two POS machines are connected to a single Enterprise database, transactions made on one POS are not visible on the other POS while performing a transaction search. iVend version : 6.5.6 / 6.6 Symptoms: N/A Resolution / work ...
POS - Transaction mode change event
Introduction: iVend Add-on Framework is used for writing Custom Business Logic independently by a programmer. iVend Addon allows to extend business logic either in Management Console or at the Terminal POS. The addon framework allows deployment of ...
