How to print from handheld deivece and what does printable option do ?
Product Version:
  1. How do we print from handheld devices?
  2. What does the printable option do in configuration?
Proposed solution:
  1. We can print from handheld devices by defining  a new document print profile for each document and setting the printer along with it. To define document print profile follow the below path, Go to Administration>Print Profile>Document Print Profile
  2. In printable option there are there option
    1. Yes
    2. No
    3. Prompt
  • When we select the yes option, the receipt will automatically print.
  • When we select the no option receipt will not print automatically.
  • When we will select the prompt option, you will get one pop-up screen form where you can select or deselect the print option.
Steps/Constraints/Scenarios:
N/A
