iVend does not allow us to delete the product once it is created.
As an alternative workaround, Follow below process with one product and check behavior.
1: Login in iVend Management Console.
Go To: Operations Tab >> Inventory Products.
2: Search the product and click on Edit button, and apply the changes.
#: Uncheck Saleable.
#: Uncheck Purchasable.
#: Uncheck Refundable.
#: Uncheck Exchangeable
#: Check the check box Is Product ON HOLD. And then click on OK button.
Restart MC and POS to apply changes.
If iVend is Integrated with SAP B1 then require to mark item Inactive in SAP.
