How to Display Report Parameter in XML
This knowledge base article will assist you with how to create a Report Parameter in XML and then how to reflect it in a Parameter Window.
Overview
The report parameter may contain multiple values in the parameter dropdown. A dropdown parameter can be used when there is a condition on an object and data needs to be retrieved based on a set condition.
Using a Dropdown Parameter in XML
Follow these steps mentioned below, which are based on filter criteria when a user wants to display multiple columns in a report:
1. Set filter criteria in a report using iVend Report Designer.
2. Now add the following code snippet in the XML file of the Parameter report.
<Parameter name="ValueCalculation" objecttype="36" caption="Values At" multiselect="false" ValidValues ="ValueCalculation"/>
<ValueCalculation>
<CostPrice>CostPrice</CostPrice>
<RetailPrice>RetailPrice</RetailPrice>
</ValueCalculation>
3. Save the Parameter XML file.
4. Import the XML and .IRT file in the iVend Report Manager.
Refer to the screen image below that illustrates the dropdown parameter.
Figure 1 Stock Cover
Parameter List
The following table documents a list of Parameters, which contains the Parameter Name and Object Type (objecttype):
Parameter List
Parameter Name
Object Type
Free Text
0
Date Only
1
Time Only
2
Date Time
3
Decimal
4
Integer
5
Boolean
6
Store
7
POS
8
Product Group
9
Product
10
Customer Group
11
Customer
12
Till
13
User
14
Payment Type
15
Warehouse
16
Gift Certificate
17
Event
18
Vendor
19
Manufacturer
20
Product Category
21
Tax
22
Coupon
23
Department
24
Reason Codes
25
Fulfillment Plan
26
Loyalty Customer
27
Loyalty Top Bottom
28
Minimum Slab Value Calculated on
29
Date Range
30
Member Transaction Calculation on
31
Boolean Type
32
Price List
33
Promotion Bonus Buys
34
Subsidiary
35
Drop Down List
36
Location
37
Employee Position
38
Security Role
39
Loyalty Program
40
Product Class
41
Till Master
42
