How to configure to have a Machine with MC and License Server connected to SQL managed Instance DB
Version
 6.6, Enterprise database on cloud
Query
The Enterprise database backup is hosted on Azure.  (SQL managed instance ) and Application Enterprise server is on premises.
So How to configure the environment to have a (on premise) Machine with Management Console and License Server connected to SQL managed Instances?
It means, How the customer can achieve the below landscape working:
Solution
If the customer wishes to use the system as per the shared landscape, then he needs to tweak the configuration of the Management console file.
In that case, he needs to add a new setting in the XML file (CXSManagementConsole.xml) in the management console folder:
(Default path: C:\Program Files (x86) \CitiXsys\iVend Retail\ManagementConsole).
Below node is to be added:
<IsHostedInIvendCloud>true</IsHostedInIvendCloud>
Attached is a sample screenshot (ConsoleXml.png) for the reference:
    • License Expired, please contact vendor
      Problem Statement: Getting an error "License Expired, please contact vendor.". However, you are using a valid license. Solution: - Please follow below steps: - Please check the regional setting of the machine and make sure short date should be in ...
    • A network-related or instance-specific error occurred while establishing a connection to SQL Server
      Environment: iVend 6.6 8567 Problem Statement: Below error message coming when tried to update iVend Connection Manager. A network-related or instance-specific error occurred while establishing a connection to SQL Server. Symptoms: User Request ...
    • Microsoft SQL Server Database Maintenance activity
      Database health check & Optimization steps Steps and walkthrough to do a health check and optimization of iVend database. The entire process broadly consists of 8 steps: Step 1: Take Backup of DB. Open SQL Server Management Studio Express and connect ...
    • compatibility version SAP & SQL Version
      Product Query Customer currently using the SQL version 2016 in HO and stores in 2008 express . SQL 2019 and higher version will support ivend 6.6? SAP Version 10 and Pl 2405 and higher PL version will compatible with ivend integration ? Answer As per ...
    • View Inventory on POS : Failed on POS machine connected to on-premises Store.
      Problem Statement There is one scenario : Getting an error "Inventory Status updated from enterprise server failed" while clicking on Retrieve from Server button at POS machine however another POS machine ( connected to same stores) doesn't have this ...
