**********Internal Purpose to CXS Support**************
iVend 6.6 With SAPB1
Problem Statement :
Stock transfer and Sale transaction events stucked on Integration Failure Monitor with error message “Insufficient quantity for item with batch in warehouse”
Below are the query used to fetch data against stock transfer and Sale Transaction for Insufficient quantity for batch in SAP
Query for fetch stock transfer data for error insufficient batch
Select a.ProductKey,Quantity, b.id,d.Id as wid,StockTransferDetailKey,d.warehousekey into #Temp from InvStockTransferDetail a ,InvProduct b ,InvStockTransfer c,InvWarehouse d where a.productkey=b.productkey
and c.StockTransferKey=a.StockTransferKey and c.FromWarehouseKey=d.warehousekey
and a.StockTransferKey in (
select SourceKey from RepIntegrationLog where Flag=0 and Status=1 and SourceType=53 and Errormessage like '%Insufficient%batch%')
alter table #temp add tempbatch varchar (200)
update #temp
set tempbatch=batchkey
from InvStockTransferBatch a,#temp b where a.StockTransferDetailKey=b.StockTransferDetailKey
alter table #temp add batchdetailorg varchar (200)
update #temp
set batchdetailorg=batchnumber
from invbatch a,#temp b where a.batchkey=b.tempbatch and a.productkey=b.productkey
select SUM(quantity) as qty, id,wid,batchdetailorg into #Temp2 from #Temp
group by Id,wid,batchdetailorg
select a.DistNumber,a.ItemCode, b.WhsCode, b.Quantity BatchQty into #batchdetail
from [SAPdatabasename]..OBTN a
inner join [Brand_Folio]..OBTQ b on a.ItemCode = b.ItemCode and a.SysNumber = b.SysNumber
select qty,batchqty as "OnHand",itemcode,WhsCode,qty-batchqty as gr,batchdetailorg from #Temp2 a,#batchdetail b where b.ItemCode=A.id collate SQL_Latin1_General_CP1_CI_AS
and b.WhsCode=a.wid collate SQL_Latin1_General_CP1_CI_AS
and a.batchdetailorg=b.DistNumber collate SQL_Latin1_General_CP1_CI_AS
and qty <> batchqty and qty>batchqty
Query for fetch Sale Transaction data for error insufficient batch
select a.DistNumber,a.ItemCode, b.WhsCode, b.Quantity BatchQty into #batchdetailsap
select a.ProductKey,Quantity, b.id,BookingWarehouseKey,c.Id as wid,a.ProductDetailKey,c.WarehouseKey into #Temp2 from TrxTransactionSaleItem a ,InvProduct b,InvWarehouse c where a.productkey=b.productkey
and a.BookingWarehouseKey=c.warehousekey and TransactionKey in (
select SourceKey from RepIntegrationLog where Flag=0 and Status=1 and SourceType=143 and Errormessage like '%Insufficient%batch%')
alter table #temp2 add batchdetailorg varchar (200)
update #temp2
from invbatch a,#temp2 b where a.batchkey=b.ProductDetailKey and a.productkey=b.productkey
select SUM(quantity) as qty, id,wid,batchdetailorg into #Temp3 from #Temp2
select qty,batchqty as "OnHand",itemcode,WhsCode,qty-batchqty as gr,batchdetailorg from #Temp3 a,#batchdetailsap b where b.ItemCode=A.id collate SQL_Latin1_General_CP1_CI_AS
None
This article is created only for Support team and such activities should be done along with product expert
