Getting Pop-up while taking a fresh backup for a store from the enterprise Management Console
Version
6.6
Query
Getting below Pop-up while taking a fresh backup for a store from the enterprise Management Console, Pop-up message says:
Taking backup will mark all non-replicated data for this store / POS as replicated. iVend recommends to take backup only if you are sure that you will use this backup at the store/POS. Are you sure you want to continue?
What is the explanation of this Pop-up message?
Answer
Database Backup
The feature enables the administrator to take back up from the enterprise for a new store.
To open the window, choose Administrator > IT Administration > Database Backup.
So above Pop-up message gives a information to the customer that, while you are taking this backup for the store, and if there are any pending records in the replication monitor from the Enterprise to Store then, all those pending records will be marked as replicated (means, these pending records from the Enterprise replication dashboard to the store (for which backup is being taken, will no more sent to the store and will be considered as those are replicated to the store) as when you are taking the backup then those records will automatically will reach to the store with the backup you are taking now.
