Record stuck in integration failure monitor having the error
Some of the possible causes with resolution are listed below:
Check details of items associated with a stuck transaction ( can be checked by expanding failed transaction in Integration failure log) and look out for that item in SAP, if it is active or not.
Check details of tax associated with a stuck transaction (can be checked by expanding failed transaction in Integration failure log) and lookout for that item in SAP, if it exist or not, or if exists then must be active.
Please check the same in the G/L Account Determination section under the Administration >> Setup >> financial. Also check details of the warehouse associated with the stuck transaction (can be checked by expanding the failed transaction in the Integration failure log) and in SAP, if all GL accounts have been defined for that warehouse. (Warehouse screen, accounting tab).
Check detail of Sales Person associated with the stuck transaction (can be checked by expanding failed transaction in Integration failure log) and verify same against the salesperson details in SAP (if concerned Sales person exist or not, or if exists then must be active)
Check for any surcharge associated with the stuck transaction (can be checked by expanding failed transaction in Integration failure log) and verify if concerned freight is available in SAP or not.
Getting the error “DI: No Matching Records Found (ODBC - 2028)” in the integration failure monitor from iVend to SAP.
The G/L account was not mapped correctly in the Item Master.
The customer had changed the "set g/l accounts by" setting for certain products to "Item Group" ( G/L account for item group was not defined) .
Records were failing as G/L account was not found.
To fix the issue, set g/l accounts by property of products was changed to Warehouse (G/L account for the warehouse was defined) . Go to SAP > item master data > Select the item > inventory data > set g/l accounts by-Warehouse (Set according to the transaction).
