GC import error "Mandatory mapping for the field is required. Field Name - GiftCertificateKey"
Not Environment Specific
Cause:
This error may occur due to the following reasons: -
  1. Wrong GC import template.
  2.  The problem may be related to the customer's database because the GC import sheet doesn't ask for the Gift Certificatekey.
Propose Solution:
Use the attached GC import template. In case the issue persists, then please try to import the GC at any other machine.
