Product Version:
iVend 6.5 update 6 Patch 2
Proposed Solution/Workaround :
It was noticed that the CXSIntegration database doesn't have correct mapping of SAPB1 and iVend Objects for Vendor group so there are following workarounds.
Update the vendor group in SAPB1 so that it could create mapping in CXSIntegration database
Suggest to create a new vendor group in SAPB1 and map the vendor to it, check if the vendor successfully gets integrated.
If the above step is successful then suggest mapping all the concerned vendor groups to the SAP B1 vendor group.
Steps if any:
Constraints/Scenarios:
