If the API service is not installed on store then following steps are needed to be performed:
1. check once all the replication is clear to and from the store.
2. need to install ivend on the store server with API.
3. Install the ivend as a new DB
4. After installation, configure iVend with the old DB ----------------------(most important and careful step)
5. After configuring replication, API and other configurations, apply the patch manually on store (same patch as on HO)
