6.5 Update 6
Enterprise visible in drop-down of replication monitor at HO MC.
This issue can be resolved by using sql query.
Issue is only reported on dated version iVend ver. 6.5 Update 6 and is not noticed on the latest branch of iVend release available for production use.
Below are the steps we require to follow-up to resolve the issue.
1.Extract the data against table RepReplicationStatus and RepReplicationSendStatus against siteid=1 on the Enterprise database.
2.After backup of table ,require to CORRECT these entries from database.
INC0011174
