Duplicate POS/MC/Hardware ID
-----Internal to Citixsys-----------
Duplicate POS
Upon copying the POS folder from one POS(say POS A) to another POS(SAY POS B). Users were unable to login to POS B. However, users of POS A were able to login into POS B
Resolution:
It was found that the Hardware ID of both POS was same. After changing the hardware ID of one POS user was able to log in successfully.
Steps to change Hardware ID:
1)Download utilities.zip folder from FTP site.
2)Unzip the folder and copy volumeid.exe in the c: drive of the pos system
3)Go to the command prompt.
4)see the volume id of the system by running the command "DIR" from the command prompt.
5)Go to the root directory i,e c:
6)run the below query from the root directory of the command prompt to change the volume id of the system
Volumeid.exe c: enter newvoulmeid(change one digit of the actual volume id)
Example : C:volumeid.exe c: 648C-46dC
Hardware list is showing Empty on Point of sale
Hardware Setup for the POS
Configuring Hardware Peripherals for iVend POS In this topic we will look at the steps required to setup, install and configure the Hardware Profile for the POS, including two main hardware components that are connected to the POS that operate using ...
iVend Enterprise Server need to replace Hardware
Environment: iVend 6.6 with SAPB1 Problem Statement iVend Enterprise Server need to replace Hardware Symptoms: User Request Pre-requisites 1. Before taking a backup of the iVend HO DB, remove the Hardware ID for User 1. 2. When you move to the new ...
Scan Sequence Resolution
POS Transaction Register: Product id filter search work based on like conditions on MC
Environment: iVend 6.6 8567 Problem statement: POS Transaction Register in iVend does not filter by product id conditions on MC Steps to Replicate: Step 1. Open the POS à Make a sale for product id "A00001". Step 2. Open the POS à Make a sale for ...
