DI: Discount amount is greater than Balance Due (Integration failure from iVend to SAP)
Product Version
6.5 Update 6
Failed record in Integration Failure monitor from iVend to SAP error says:
“DI: Discount amount is greater than Balance Due.”
Proposed Solution/Workaround
One of the known issues for this error was about installed iVend Add-on. So as the first troubleshooting step you should re-install and re-register iVend Add-on as per your machine and SAP Bit (32 Bit 64 Bit).
Follow the below steps to solve the concern:
· Un-install the iVend add-on in SAP
· Re-install the iVend add-on in SAP
· Remove entry from configuration window and add again
· Tools > User Defined Windows > CTX_CONF Configuration
Remove CTX_IVEND4 entry and re-registered the add- on
· Start iVend Add-on
· Stop the integration
· Clear the temp folder.
· Restart the integration service.
· Retry all the records in the Integration Failure Monitor.
    • A/R Invoice see different discount between iVend and SAP B1
      Problem Reported : Customer notified to us about different A/R Invoices between iVend and SAP. they realize that they have a difference in the discount between SAP and iVend, it is showing discount negative and decimal less than one. Cause : ivend ...
    • Error in Integration Monitor (SAP to iVend) in version 6.6 for event type "Customer"
      *****************For Internal purpose********************* Product Version: iVend 6.6 Issue: Error in Integration Monitor (SAP to iVend) in version 6.6 for event type "Customer": Integration Error: System.Data.SqlClient.SqlException (0x80131904): ...
    • Payment amount is greater than invoice amount Integration Error
      Problem statement : Incoming payment is stuck in Integration Failure with the error message: "DI: Payment amount is greater than invoice amount" from iVend to SAP iVend version : Not version specific Symptoms: NA Resolution / work around : Error ...
