6.5 Update 6/6.6
Data Template is required to use in iVend MC--> Inventory Transaction Screens such as inventory counting .
Proposed solution:
Suggested to use the below format for Inventory Counting and also suggested to check various format for different document which are available on below path.
C:\Program Files (x86)\CitiXsys\iVendRetail\ManagementConsole\Import Templates
//Normal Product: ProductId,Quantity //
100102,5
100103,6
100104,7
//Serial Product: SerialNumber,Quantity //
1001,1
1002,1
1012,1
//Batch Product: BatchNumber,Quantity //
B100,8
B101,9
B121,5
If Location is enabled: Suggested to use the below format for Inventory Counting if location is enabled
ProductID,Quantity ,,LocationID
Note : There are double comma(,,) before LocationID
Steps if any :
Constraints / scenarios:
