customer display screen not able to launch in Taskbar.
Problem Description
Solution
Need to check the connection string in CXSCustomerDisplay.xml file .then it should be corrected below format
<OfflineConnectionString>Server=CXS-XXXHULR; Initial Catalog=POS; User Id=sa; Password=XXXPwd@123##; Application Name=CXSPOS</OfflineConnectionString>
None provided.
