Consuming iVend Retail Web API Using REST Call
This knowledge base article provides an overview about how to consume the iVend Retail Web API using REST Call.
Purpose
The key purpose to use REST Call is to make the iVend Retail APIs platform independent, language independent, and run services on HTTPS.
Consuming the iVend Retail Web API using REST Call
With WebHttpBinding endpoint, iVend Retail API is exposed through HTTP requests which can be accessible simply by URL.
The following steps provide an explanation for consuming the iVend Retail API using REST Call with authentication:
1. Define the REST Service URL.
//Declare Rest service URL
1. Create an HTTPWebRequest object with the provided REST service URL.
HttpWebRequest request = (HttpWebRequest)WebRequest.Create(URL);
1. Provide the method type and content type to the request.
1. Pass the header value(s) to the request.
1. Initiate the request and get the response.
1. Check the StatusCode from WebResponse.
Refer to the following screen image of sample code for further guidance.
    • Consuming iVend Retail Web API Using REST Call
      Introduction This knowledge base article provides an overview about how to consume the iVend Retail Web API using REST Call. Purpose The key purpose to use REST Call is to make the iVend Retail APIs platform independent, language independent, and run ...
    • Calling iVend Retail Web API using SoapUI
      Introduction This knowledge base article explains about using SoapUI in an iVend Retail Web API Call. SoapUI is one of the simplest designed applications to test web services. Overview In this article, you will learn how to use SoapUI in the iVend ...
    • Calling iVend API through REST
      Introduction iVend Retail Solution delivers a configurable, flexible, and scalable solution that is easy to setup and implement. iVend provides a rich bundle of APIs that can be leveraged to integrate using a program with any standard ERP of choice. ...
