Configuration Package
iVend 6.6 Demostack
Problem Description:
Client can't find the configuration package described in the post below, can you please help me or verify if this tool was discontinued or how can it find it? I am using iVend Demostack.
Scenario:
Client is using iVend Demostack which is a preconfigured solution.They have a query that whether the configuration package works for Demostack or not.
We have suggested that DemoStack is a preconfigured system to demo ; But Configuration Package is used to migrate existing Profiles from iVend to another iVend and generally it is used to move profiles from UAT to Production in iVend implementations.
N/A
We have informed customers about the limitation of Demostack and how the iVend configuration package works for iVend implementations.
