Communication Settings TEST EMAIL not working
Unable to Test Email in Communication Setting iVend Retail.
1: Login in iVend Retail Management Console.
2: Go to: Administration Tab >> Communication Settings >> Click on Test Email button.
3: Enter the valid email address and click on OK button.
Error: Below error appeared while trying to Test Email.
Solution
​Try following steps to solve the problem.
1: Make sure SMTP details (Server Host) should be correct in iVend Communication settings
2: User Password Should be correct.
3: Uncheck the Enable SSL and try to Test Email
