Change Warehouse Code
iVend 6.5.6 ,6.6
Problem Description :
For new warehouse created need to change the Warehouse Code in iVend system.
Scenario :
Client  have moved to a new warehouse & need help to change warehouse code for the store, what is the best way to process these changes; current warehouse set to 01 & need changed to 00.
Workaround :
N/A
If a warehouse has been created and attached to a store then it remains same. There is no possibility to update it from application if need to attach to a store then create a new store in iVend and attach the store to the desired warehouse(Which is newly created).
    • Restrict particular users to access warehouse
      Environment : iVend 6.6 with SAPB1 Problem Statement : There is need to restrict particular users to access warehouse & its relevant information in iVend Various Screens. Resolution/Work Around : Whenever you create any warehouse in SAPB1 , it will ...
    • Unable to change the Warehouse Type from MC
      Version: Ivend 6.6 Product Query Unable to change the Warehouse Type from MC Resolution We would like to inform you that there is no provision of changes in the created warehouse, Suggestions: If no transactions have been created with this warehouse, ...
    • Is it possible to change the In-Transit Warehouse that is assigned to the Store Warehouse
      Environment: iVend 6.5 Update 6 and 6.6 with SAP B1 9.2 Problem statement: Is it possible to change the In-Transit Warehouse that is assigned to the Store Warehouse Symptoms: Is it possible to change the In-Transit Warehouse that is assigned to the ...
    • UPC Code
      UPC Codes What is a Universal Product Code (UPC)? Simply put, a UPC, short for universal product code, is a type of barcode printed on retail product packaging to aid in item identification of a particular item. It is most widely and commonly used in ...
    • Tax Code Decimal Precision.
      Environment: iVend 6.6.8929 with SAP B1 9.1 Query: There is a requirement from the customer regarding Tax Code Decimal Precision up to 3 decimal places. Resolution/Work Around: We have suggested the customer to make the below change in iVend HO MC : ...
