iVend 6.6 7989 With SAP 9.3
Can we hide For store and Store ID fields from SAP Purchase Order Window ?
Proposed Solution/Workaround:
When you start the iVend addon in SAPB1, few fields such as FOR STORE will be visible on SAPB1 Purchase Order or Inventory Transfer screen so it is handled by iVend Addon only and It is also recommended to keep iVend Addon running in SAPB1.
Apart from this one, there is no configuration setting to control these fields to enable or disable.
