Can we change "Costing Method" of a product from "Average Cost" to "Standard Cost" and vice versa
Version
6.5 Update 6, not the version-specific
Query
Can we change the "Costing Method" of a product from "Average Cost" to "Standard Cost" and vice versa? Below is the screenshot for the same:
Response
The "Costing Method" once defined can't be changed. This is a system by design.
