When a user is trying to update a price list name in SAP, it will freeze for 20 minutes or longer and then the system will crash. There is enough free space but every time the system crashes it is due to memory issues.
1.Check the db fragmentation . if high make it low
2.Check the rep integration log table whether the junk data is there or not if junk data is present in table remove the junk data
