Best Practices for iVend Upgrade
The links and the artifacts below are the tools that you would need to enable and ramp up on iVend Retail Management Suite. This content is divided into 2 sections – one for the Sales Consultants and the other for Implementation Consultants. However, in this article we will focus onthe content curated for the Implementation Consultant's. The links below are organized in the chronological order of their usage and will help you as a sales or an implementation consultant to get yourself certified.
The following guides talk about the best practices you should follow when you are looking forward to an iVend Upgrade.
- iVend Retail Upgrade Manual - Document
- Upgrade Project Plan for iVend POS version 1.0 - Document
Competitive Research
Introduction This article contains links to all the applicable resources for iVend Retail Channel Partner Sales, Marketing and Implementation roles. The entire resource is split across the following subsections: Brochures and Factsheet Competitive ...
iVend Report Designer
Introduction This article is divided into sections and contains links to all the applicable resources for iVend Retail Channel Partner Sales, Marketing and Implementation roles. iVend Report Designer Below you will find links to all applicable ...
iVend Retail
Introduction This article is divided into sections and each section contains links to all the applicable resources for iVend Retail Channel Partner Sales, Marketing and Implementation roles. It is spread across the following sections: iVend Retail ...
iVend Dashboard Designer
Introduction This article is divided into sections and contains links to all the applicable resources for iVend Retail Channel Partner Sales, Marketing and Implementation roles. iVend Dashboard Designer Below you will find links to all applicable ...
iVend Hospitality
