6.6 demostack with SAP B1 10
Initializing demostack with SAP 10 and iVend Add-on in SAP B1"object reference not set to an instance of an object"
Not Applicable
iVend 6.6 Demostack is compatible with SAP Business One 9.3 PL 12 (64-bit) ( not with SAP B1 10) .( refer to check available iVend 6.6 Demostack pre-requisites document)
Additionally, iVend Demostack database can't be changed into customer database so customer will require to install iVend 6.6 using available 6.6 Installer( not demostack ) and initialize the iVend with SAP B1 10.0
Not Applicable
