2 SAP HANA databases on the same SAP HANA server and connected to 2 separate iVend HO SQL
iVend 6.6 with SAPB1 HANA
Problem Statement :
Can 2 SAPB1 HANA databases (which are on different HANA servers) be on the same SAP HANA server and connected to 2 separate iVend HO SQL servers?
Symptoms :
Integration of multi company SAPB1 HANA with corresponding iVend Enterprises
Resolution :
Yes, 2 SAP B1 HANA databases can be configured on the same SAP HANA server provided both the iVend versions should also be the same .It should not conflict when you install the iVend addon.
Steps if Any :
SAP Business One - iVend Retail Integration Points
Steps to pulls SAP data /Table from SAP HANA Database to iVend SQL SERVER
Requirement While working with an Integration iVend Solution in a SAP HANA environment, sometimes it is required to have SAP DB access via linked server. The inventory mismatch correction process is the most common such scenario. In such a scenario ...
iVend ADDON for SAP BUSSINES ONE - HANA and SQL
Version: 6.6, not version-specific Request: Customer requires Addon for iVend 6.6 with SAP HANA Resolution: Please download the latest patch 7915 from the CitiXsys Support portal (https://citixsys.service-now.com/) which contains the updated Addon ...
Production and Test HANA Databases on same server for Ivend Version 6.5.6 and 6.6
Environment: iVend 6.6 With SAP B1 HANA Problem Statement: Customer upgrading iVend to 6.6. They are currently running iVend 6.5.6 integrated to SAP HANA. Customer wants the SAP HANA server will host both the production AND the test SAP HANA ...
Linked server creation from SAPB1 HANA Server to SQL Server
Environment : iVend 6.6 With SAPB1 HANA Server Problem Statement : There is need to access SAPB1 HANA tables on iVend Enterprise database Resolution : You can check out the below video link to create Linked server from HANA to SQL Server ...
